2********
09-22-2018 08:29 AM - edited 01-05-2022 05:44 AM
Now 5 days. My phone 2**********.still no connection .Y is this dam service .Y can't correction your foult .if u can't keep promis don't keep promotion .Pls answer
Service
09-22-2018
01:01 PM
09-24-2018
09:25 AM
Mary_M
They are not even resolving issues for more than 96 hrs - crappy crappy service.
09-22-2018
10:25 AM
09-24-2018
09:18 AM
Mary_M
First of all, i'd delete your phone number from the post and suggest you try to contact the mod team if your experiencing issues like this. Your post is not very speific. Is it possible to give us more details?
Here is the info to contact the mod team. https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/The-Public-Mobile-Moderator-Team/ta-p/...
09-22-2018
09:14 AM
09-24-2018
09:18 AM
Mary_M
@Lankanatha, what is the issue exactly? Additional details would help direct you in the right direction. Most account related issues need moderator intervention. Have you contacted them? Did they reply? They are on. A 48 hour turnaround at the moment.
Also best to remove your tell number from the post
Also what phone are you using? Can you try the sim in another phone? This isolates hardware vs account issues
