2 eSIM in one phone?
luckylucky2020
My phone is broken, and I want to buy an eSIM to transfer my line to an iPhone 13 that already has an active eSIM. Is this possible?
luckylucky2020
Thank you very much for your most appreciated support.
so, via the app, I login to the account of my line which is on the broken phone and I want to transfer to the iphone, and then I purchase a new eSIM, and automatically my other line is registered on the new esime and is usable on the iPhone?   my contact numbers / whatsapp account / and public mobile rewards all get transferred to this phone?
Socrates8567
@luckylucky2020 wrote:
Thanks a million, your reply was very helpful.  I am just a bit concerned as am not sure by buying an new sim or eSIM for my existing line to add it to a new phone will not cause any interruption or cancelation of my line/number.
So what you do is this. You just download the app on your new phone, you can "purchase" a new eSIM as it will show $5. However, if you've purchased one already, at checkout, it will be free. It's that easy.
With regards to getting a physical sim card, I thought about that too. But I prefer to keep my sim slot open just in case I go for a trip somewhere and I can just use a local sim card there since public mobile only works in Can US and Mex.
luckylucky2020
Socrates8567
Hello.
YES!! I have an iPhone and have 3 eSIMs. Only 2 can be active at a time. Just set one as primary. Just know that you can only be on one "line" and the other will go to voicemail or the iMessage will come after you're off the other line
