11-16-2025 07:09 PM
Switching now from the $15 plan since the price is being forced and my subscription renews in 3 days.
What's the difference between the $19 and $18 plan? 2 extra cents from the rewards points? 🤣
11-16-2025 08:22 PM
Some actually see a $19/2GB after changing to $18/1GB. So, take the $18/1GB first and keep checking if you see the better $19 deal after
Noted
11-16-2025 07:20 PM
11-16-2025 07:11 PM
hi @OldRewards
no difference. if you can still take the $18 plan, take it first.
