4 weeks ago
Received offer with code. Code is invalid. I see this is happening to many people. Where can we get correct codes?
4 weeks ago
@MAiken wrote:Received offer with code. Code is invalid. I see this is happening to many people. Where can we get correct codes?
Hello @MAiken
Please take a look at this link here for the solution. This seems to be a mass problem a lot of people are having.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Texted-promo-code/td-p/1454252
4 weeks ago
Some can add it only on My Account using the browser, but some come only use it with PM app, so try both
But if neither works, then you will need PM to apply it for you. Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
