$15 plan
Seabass1
How do I change my subscription to the $ 15 plan?
Seabass1
Unfortunatley , its not there .
Cheers
hairbag1
@Seabass1
PM has changed the plan menu...it's now dependent on which plan you currently have. You must do as previous suggested...log in to your account to see which plans you can changed to. I have the old $15 plan but looks like the cheapest option for me now is the $19 plan. That may not be available to you either, depending on which plan you currently have. Keep watching your plan menu though because plans come and go with frequency now.
TheSterlinger
@Seabass1  unfortunately there is no more $15 plans.
Do you see it in your account?
You have to sign in and switch to what is showing as available in My Account.
