05-01-2019 09:22 AM - edited 01-05-2022 04:41 AM
if i get the 15$ 100 talk plan and then buy the 400 minute ld add on and happen to go over the 100 minutes in my 30 days could i use the 400 minute ld add on to 'extend' my minutes for the thirty days? or is it that if i go over my 100 minutes then no out calls whatsoever?
05-01-2019 09:29 AM
thank you both
05-01-2019 09:27 AM
Hi, From what I read, the add-on will give you 400 min after your 100 is used up.
Add-ons carry over , you dont lose your balance after 30 days.
05-01-2019 09:25 AM
yes, you can use this add on 400 after you go over 100 mins, this add on will stay in your account and carry forward until you used up.
