$15 A MONTH = CHEAPEST PLAN?
RNGR_ROB
Hello everyone, first time posting, looking to see if the 15$ is the cheapest plan at the moment?
I have a new plan with another carrier, but want to keep my PM number as a back up!
I've had PM for a while but never posted here in the community, never understood how to get bonuses or "Bravos".
Thanks! And Happy Saving!
jor123
$15 is the cheapest, but you can get it down to $13 pretty easily with autopay and over the years  with the loyalty bonuses (plus community rewards if you participate here).
dude65
$15 is currently lowest costing plan at PM. Add a CC to autopay and deduct $2/month, Every friend/relative you refer to PM saves you $1/month. Post in the forum and you may receive a reward.
kselmak
@RNGR_ROB
It is cheapest at the moment
You have couple of options, if you have rewards and want to receive them I suggest keeping account active, you can forward all your calls to your other number (forwards seem unlimited so far)
If you don't care about collecting your reward and loyalty time you could be paying 15 every 110 days by letting your account expire for 80 days. Note that your calls would be possible to forward only 30 days after payment, once it's expired calls fail until the account is reactivated again
Right up there next to the big PUBLIC logo...Plans. That's what's available.
Getting community rewards depends on your participation level in the community. Be helpful, maybe someone will give you a Bravo. Maybe even your helpful answer solved the problem and your post will be marked as the solution.
kb_mv
@RNGR_ROB The $15 plan is the cheapest at the moment. If you just want access to your number as a back up in case you might need it, you could always let the account be suspended (don't pay). You then have a dormant/suspended account that you can keep that way for up to 90 days (better to pay around 85 days just in case). After you make another payment you are good for 30 days, let it be suspended for another 90 etc etc tec.
