03-22-2019 10:35 PM - edited 01-05-2022 03:53 AM
Does "Unlimited International Texts" mean ALL texts, local plus texts from anywhere?
Joining Public
03-22-2019 11:34 PM
Thanks for the great answer. You sound like the same type of user I am.
03-22-2019 11:15 PM
Yeah the 15$ plan is pretty amazing and you get data as well as 100 minutes and unlimited texts if you set up auto pay its pretty unbeatable for low data users. And with auto pay you also get 2$ off/30day making the plan even cheaper. Not to mention the other ways of getting the cost down each month like friend referrals. As long as you only use the data for gps, email and the odd web search you shouldn't run out as that is what i use my data for mostly and works great.
As to the texts yes your texts can go to anyone in the world while you are in Canada. Just be careful that when you are in the United States or other countries you look into get the proper roaming add on so that if on vacation there you can get it to work there as well.
03-22-2019 11:06 PM
Porting your number is very easy. There is something to know though and that is that it will take a while once you start the process. Mobile to Mobile will take up to half a day (If it takes longer than 24 hours usually there is a problem)
Landline to Mobile take a few business days up to a week.
VOIP takes up to a week.
You should take a random number from the pool then after your account is good to go, start the port process.
Feel free to send me a PM if you need someone to help walk you through it.
@ecowen wrote:This sounds too good to be true!! As soon as my old plan is done, I'll move to Public. Just have to figure out how to keep my number.
03-22-2019 11:06 PM
03-22-2019 10:39 PM
yes you can send texts to anywhere in the world, hence international in the name
03-22-2019 10:39 PM
03-22-2019 10:36 PM
@ecowen wrote:Does "Unlimited International Texts" mean ALL texts, local plus texts from anywhere?
Yes it does. As long as you're in Canada, you can send / recieve all the texts you want ...from anywhere. Welcome to Public Mobile.
