10-16-2020 10:07 AM - edited 01-05-2022 03:46 PM
hello,
I used my referral code for a friend to activate his Public Mobile phone plan.
However, I did not receive my 10$ credit? Or it's not shown on my account!?
thank you,
10-26-2020 04:23 AM - edited 10-26-2020 04:28 AM
I knew by the cha-ching that you were talking about the text not an email....people call private messages emails all the time too....no biggie. Don't worry about being corrected its all in the learning process. When I first started and still do when i mix up the correct answers or have a brain fart and I have been corrected I just say thanks....my bad and go to my post. I then right the wrong and highlight the correction in bold lettering or red or maybe green. And make a note of my edit like this:
Edit: oops! I meant to type text not email.
Thx @AE_Collector
Edit again! Oops i forgot to add this for the OP.....
Did you recieve one of these texts from 100 (pm short code)?
10-25-2020 08:28 PM
10-25-2020 06:03 PM
Trying to be helpful before my time
It was actually a text
Will hold off until I know more
Thanks for being a watchdog of sorts
10-25-2020 05:03 PM
@Kered13 wrote:Once your friend is set you will receive a chi ching email if you have clicked the email me when someone replies box to the right of the subject line here.
You will receive a dollar of each month so long as your friend stays with public mobile. Your friend will receive a one time $10 credit. If you have more friends, have them switch here using your referral code. In no time your phone bill could be 0
Public Mobile doesn't send any e-mail mesaages to confirm that you've referred someone.
10-25-2020 03:29 PM
10-16-2020 11:27 AM
@Adnaned wrote:Get referred and you'll receive a one-time $10 credit! <- This applies to your friend
Plus we'll take $1 off your payment every 30 days for every friend you refer for as long as they stay with us. Sharing is caring! <- This applies to you, you should have received a Cha Ching text from Public Mobile.
10-16-2020 10:50 AM - edited 10-16-2020 10:53 AM
@Adnaned if you still haven't received the $1 credit. your friend will need to contact customer support mods
click on the question mark chat bubble to the bottom right of your screen
type "missing credit
(use the chat bubble options, then click "submit a ticket, click me" option)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
some of the categories in SIMon are broken follow these steps to submit a ticket
after the page opens, click the dropdown menu and select "other"
then select "something else"
then "next"
and then write your issue in the box and click "submit ticket"
10-16-2020 10:29 AM
@Adnaned wrote:Get referred and you'll receive a one-time $10 credit! Plus we'll take $1 off your payment every 30 days for every friend you refer for as long as they stay with us. Sharing is caring!
@Adnaned That is exactly why you didn't receive a $10 credit. You were not referred, your friend was. You will, as others stated, receive $1 per month credit for each month your friend/referral stay active.
10-16-2020 10:21 AM - edited 10-16-2020 10:24 AM
The person making the referral (you) should have received a “congratulations” text very soon after the friend activated. Either instantly or the next morning if the activation was done in the evening. Did you receive that text message?
If you look in your account you should see $1 on the Refer a Friend line. This will be used to supplement your next renewal. The $1 shows up instantly when friend activates.
If none of this happened your friend either didn’t activate, gave/used your referral code incorrectly (typo - O/0, 1/!/l etc) or maybe a store clerk entered it incorrectly or they used their code instead?
Your reined should see their $10 one time reward in their account usually a day later but it can take up to three days to show up.
AE_Collector
10-16-2020 10:20 AM
@Adnaned , go into your self serve account, rewards tab and click on the little triangle to expand the rewards information. If you see your friend's phone number (last 4 digits) there, everything is in order and you will receive $1 for each renewal provided your friend maintains their account in active status.
10-16-2020 10:14 AM - edited 10-16-2020 10:21 AM
Your friend got referred by you If he used your code. Friend gets the one time $10.
If friend plans on staying here for quite awhile you are better off with the $1 credit every 30 days.
AE_Collector
10-16-2020 10:12 AM
10-16-2020 10:12 AM
It's more than a week now!?
10-16-2020 10:11 AM - edited 10-16-2020 10:12 AM
Mine took about 1 week to show up. That's the $1 monthly bonus I'm talking about
10-16-2020 10:11 AM - edited 10-16-2020 10:16 AM
You don’t receive the $10, your friend does.
You will receive $1 per month credit as long as your friend remains a customer.
AE_Collector
