$10 Plan
dickwong
Does this plan come with the 4 different call forward functionality?
Are both loyalty and autopay reward applicable if I change my current plan used since 2016 to this?
geopublic
@dickwong  Yes it does support all cal forwarding options.
Yes, AutoPay and loyalty rewards are associated with your account not your plan.
TheGx
popping
I am getting loyalty, autopay and referral rewards on my $10 50/50 plan.
I have not try the call forwarding on this plan.
RossN
@dickwong hi yes you get call forwarding but remember that it counts against your minutes to retrieve messages and yes auto pay is still there plus your loyalty rewards
@dickwongIf you change to this plan, you WILL be eligible for loyalty & autopay rewards (plus community rewards).  As for call forwarding, it should be the same as any other PM plan.
