Wifi doesn’t work!
Nwnl7878
Why has my wifi stoped working
Provide us more information and we will try to help...
What is not working ?  Like your phone can't see your home wifi network at all? or it sees it but no longer connecting?  or you can't turn on Wifi on the phone?  Did you try another Wifi network?
@Nwnl7878 ,
Are your other services (calling/texing) working okay?
Hi @Nwnl7878 ,
Do you mean Data or are you in a Wifi Zone area?
If this is Wifi, then are you having an issue with a modem/router? Are other devices working with Wifi?
Gunner123
@Nwnl7878 Public has no control over your wifi do you mean data ? if so check your self serve under plans and add ons  to see if you used it all
