04-25-2024 04:18 PM
On the Public home page I get a banner that says - “For a limited time, subscribe to a 4G 20GB plan for only $29/month.” Just so happens I’m interested in that plan so click it and you get the tag on the right in picture. However, going to the main Plans page gives you the tag on the left. Failing to see what the promotion is unless it’s the $.40 more in points. Wow, what a deal! To me the offer of $1.05 seems incorrect anyways as it’s not the 5% that we are supposedly getting.
Where’s the deal??
05-05-2024 09:53 AM
I took advantage of the $75/3 month plan. And it's gone in may.
04-26-2024 10:51 AM
So overnight the elves were working and introduced all “new” 4G plans with the option of a subscription.
04-25-2024 11:26 PM
@klr4evr The other thing I forgot to mention is that up to a couple of days ago, the $29 plan only came with 10GB of data. The “promotion” is likely the increase to a 20GB allotment.
04-25-2024 09:14 PM
@klr4evr - Yes, instead of following freedom they should do more competitive plans like 60GB $34 Canada us. Or a $29 30GB canada wide and maybe have this like Koodo's pick your perk system with 1-2 perks available but with unlimited data at no charge:
| Category | $29 and lower (4G) | $34 - $49 5G | $50+ 5G |
| Perk 1 | Reduced speeds of 256kbps | Reduced speeds of 1mbps and 500mbps 5G speed booster. | Reduced speeds of 1mbps and 500mbps 5G speed booster. |
| Perk 2 | Canada-US roaming with 10GB talk + text / month | Canada-US roaming | Canada-US roaming |
| Perk 3 | LD pack | LD pack | LD pack |
| Perk 4 | Wi-Fi calling | International roaming | International roaming |
| Perk 5 | N/A | Mexico roaming | Mexico roaming |
| Perk amount ($5 / month per extra perk): | 1 | 2 | 2 |
If it doesn't appeal to you, then maybe a higher range of plans like a $29 40GB 5G plan and a $29 30GB 4G plan with Canada - US plan.
04-25-2024 08:59 PM
Thanks @fixin1 for putting that up again. I couldn’t remember what the previous offers were. Would be nice IF that was the “promotion” offer. Instead of following Freedom it’s time that PM took the lead.
04-25-2024 08:31 PM - edited 04-25-2024 08:33 PM
@klr4evr - They (PM) used to offer this plan for Boxing "Week" / Month of December deals:
30GB of data at 4G LTE speed of 100mbps for $29. It may come sooner or later but they usually base it off of Freedom / mainstream competition since freedom has for $29 20GB Canada-us PM has a $29 20GB Canada wide plan.
EDIT: The post above is from the deadline from my old community account here by fixin (Not fixin1): https://productioncommunity.publicmobile.ca/t5/The-Lounge/Boxing-Week-Promo-Plans-end-Today-Updated-...
04-25-2024 08:27 PM
The free ESIM is offered on both. There is clearly no “promotion” here.
04-25-2024 07:43 PM
Good catch. Another fine example of the clear and effective communications that PM is renowned for /s
I’m pretty sure its supposed to be $1.45 (5% of plan cost). Maybe the “promotion” is the free esim (a huge $5 savings). Its about on par with their whopping one-time $15 win back offer
04-25-2024 05:56 PM
I’m not so much concerned about the point difference. I don’t get where the “promotion” is when both plans are the same. My thinking is they should be matching the NoName offer @ 30 GB.
04-25-2024 05:34 PM
@klr4evr - Maybe just a glitch in the matrix. PM will find out and fix it. Just ignore it and if you only receive 1.05 points contact CS_Agent here:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
