11-15-2022 10:54 AM
Do you charge your phone to 100% or do you use any 'battery saving app' where you can limit charge to 80%,90%, etc %?
Even my laptop has BIOS option do I want 'battery saver' - 80% charge or 'longer work' - 100% charging.
Should I bother with those 'battery saving apps' at all since they use some battery juice while running in the background.
11-20-2022 01:27 PM
I usually charge @ 30-96%. the most important thing to do is to recalibrate the battery at least once or twice per year. especially if you notice the battery draining quickly. ie. 100%-90% in 5 min or if the device just randomly shuts off when theres still battery remaining.
11-16-2022 12:03 AM
Technically yes. Lithium is limited by the number of charge cycles. The more often you charge the phone the more often you deplete the chemistry in the battery. I Charge to 100% via slow wireless. I also dont charge my phone every day or before bed. Try charging when you need to. Run it down to 30 or 40 percent, it may 1.5 or 2 days. Meaning when I go to bed and my phone is at 61% I leave it until Lunch time to see if I need to charge it up. Fast charging will also deplete the chemistry faster.
11-15-2022 12:04 PM
I could but still want calls to go though just in case of an emergency from a family member.
11-15-2022 11:39 AM
@BKNS27 wrote:I also put the phone on air plane mode while sleeping…this was the biggest help with battery drop.
Why not just turn phone off?
11-15-2022 11:06 AM
I normally to 100% but I don’t charge while sleeping or unattended.
I stopped using a battery saving app but I had problems with the app and it really didn’t help save battery life.
Stopped using wireless charger as it heats up my phone. As heat reduces the battery life.
11-15-2022 10:57 AM
HI @Yummy
I charge to 85%. Not sure if it is really good to the battery but seems like it is advised to do so
