Pokemon go - Saving Data
Quackers
Does anyone know of any good ways to make sure Pokemon go uses up less data as you use it? I'm currently on the $15 / 30 days plan and I want to make my data count.
Thank you for any contributions!
1 REPLY 1
darlicious
@Quackers
You should already have your data tracker and saver on. Turn off all background data including your Pokemon app. Set your data tracker for half of your plan data so it turns off alerting you to how much data you've used. Continue to have this set at every 100mb especially for data add ons as they have no warnings sent to you when they are 75% or 90 % used.
