Mobile Data and Maps
dyardeni
Hello,
When using any Maps application and wanting to save on your data usage, simply turn on data, put in address and "start" directions. Then turn off data. The directions in the maps app will continue to work as it is based on satellite. You do not need data to have it running. True, you won't get live updates, but at least you saved some data.
2 REPLIES 2
dust2dust
I'm going to try that starting with wifi instead of data. One would think it should be the same idea. And of course you can download map areas for offline use. The GPS will still locate you on the map without the internet.
@dyardeni good tips  But with this setup,  make sure your follow the direction closely as the map app cannot recalculate
Another data saving tips is to download the map offline ahead.
