How to turn off Glance in Motorola G13 without messing up other settings?
Islasmith
Hey everyone, I recently got a Motorola G13 and I'm trying to disable the Glance screen feature (the one that shows notifications when the screen is off). I've looked through the settings but want to make sure I turn it off without accidentally changing other important settings. Has anyone done this before? Would really appreciate some clear steps. Thanks in advance!
Islasmith
Got it buddy
Islasmith
Ok thanks buddy
Joe_G
I would recommend disabling Glance.
Settings > Apps > See all apps
Touch 3 dots upper right, select Show system apps.
Scroll down select Glance and disable.
@Islasmith  I found this
Steps to disable Glance in Motorola device:
  1. Step 1: Open "Settings" on your Motorola device.
  2. Step 2: Tap "Display" after scrolling down.
  3. Step 3 Select "Lock Screen" within the display settings.
  4. Step 4: Tap "Glance for Moto."
  5. Step 5: Toggle it off to disable Glance on your lock screen.
