07-03-2017 01:44 PM - edited 01-04-2022 02:16 PM
Hi!
What should I do to make my daughter's phone plan accept her calling Ontario? She is temporarily in Quebec for 6 weeks summer job and she is not able to call me or anyone within Quebec using her phone and she is stuck. We are new clients of Public Mobile, and not able to call customer service to seek help is highly frustrating. I hope someone gets back to us asap and help us resolve this problem as quickly as possible. Thanks.
S.
07-03-2017 03:39 PM
Hi I just purchased the 400 min canada wide "add-on" and hopefully she should be able to call within QC as well as Ontario. She is at work right now and said would call to check later to see if it works. If she has wi-fi, then ofcourse she can use skype or watsapp..... thanks for your timely response.
07-03-2017 02:11 PM
07-03-2017 02:10 PM - edited 07-03-2017 02:11 PM
Calling Quebec while in Quebec should be possible even with an Ontario number and province wide calling plan. However, long distance add-on is needed to receive calls when outside of the home province. Using VoIP apps is a potential solution if you don't want to spend money on add-on.
07-03-2017 01:56 PM
07-03-2017 01:48 PM
07-03-2017 01:48 PM - edited 07-03-2017 02:00 PM
What calling plan does she have:
If she has provincal calling, she will need to buy a long distance add on, so she can call you. If you call her she should be able to receive calls so you could always call her if need be
If she has Canada-Wide, then calling should not be an issue
Edit: If she is unable to call anyone, then perhaps something went wrong in the port process if a port was requested fairly recently. Does she have access to text messages and data?
