Re: Good things come in two!
manujai786
I have a question is it possible to change the plan in PM in between the plan bcoz it says you can change your plan on your next renewal date plz tell me
@bhavpate4 wrote:
i am new member... will wait fo new promotion
Public Mobile often has promotions on weekend. Unfortunately, we usually only find out as the promotions is about to start.
bhavpate4
GinYVR
@manujai786Yes you can change the plan any time during the month (if I am reading you correctly).. however since the plans are prepaid, you will forfeit the amount you had paid eg if you change plan on the 15th day of the your 30 day plan, you loose the balance of your plan and get charged a new 30 day starting on that day.
