android 8.1 apn settings
dennis1
I have an UMIDIGI A3 with android 8.1 and I can't edit the apn. How do I connect to the internet?
Yes, I have a data plan.
There are 2 apns listed under Access Point Names in my settings. They are TELUS SP (sp.telus.com) and TELUS services (services.telus.com). Neither of these are editable.
There is also an IMS.
This is very frustrating when I rely on being able to send and receive photos via text.
It would be nice to have a number to call for tech support when the Comunity can't help...
10 REPLIES 10
@dennis1 wrote:
droid and google fixed the issue
Great news. Thanks for taking the time to provide an update
dennis1
dennis1
android 8.1 updated the OS and google updated mobile services app.
All is fine now after a reset to default APN.
Thanks
Janterry
I had the exact same issue.  What worked for me is I ordered a Roam Mobility sim card (Amazon $4.95), took my PM sim out, popped the roam one in, was able to manually add PM APN, put my PM SIM back in and Voila!
dgarewal
Try going to Network - Mobile Networs - Access Point Names - then triple tap on the three dots on the top right corner.
I just tried it on my Android 8.1 phone and it worked.
hycm53
Since it’s Android 8.1 issue, there’s no option to change APN nor to add new APN, you can try above someone’s suggestions, or can you try install this app, it works for my ASUS Zonfone 4 MAX (Android 8.1).
https://onedrive.live.com/?authkey=%21AAlIArKAxUmztZc&cid=C48A9603A89C84E3&id=C48A9603A89C84E3%21160...
geopublic
The only way to get it working is if you have a Freedom or a Roam.com sim card (others have also mentioned Speakout). Those cards apparently will allow you to add an APN. So just use the card and add the Public Mobile apn. Another option is to install a non Google Play app.  More info here  and here
Hope this helps.
GR
Maybe you'll have to get in touch with support from the phone manufacturer!  Read up on this, it might help. https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Android-8-1-APN-settings/td-p/241715
dennis1
There is no advanced settings.
GR
Try this to start
