Reply
Re: My stepdaughter
Re: My stepdaughter
@CalgaryBen wrote:
@Alex888 wrote:
Did she set up a credit card for auto-pay? It doesn't count if she just pays it early every month, even if she uses a credit card, it has to be authorized to automatically withdraw the funds when requested.
Wait, what?  No.... that's not right.  If AutoPay is enabled, the system should be applying the $2 AutoPay Reward regardless of how/when you add funds.
@Sarahmulder28 any chance you could go to the self-serve site for your stepdaughter's account, go into Payment --> Transaction History, and Search for the last 6 months?  A screen shot of this would help immensly with understanding what's going on.
Also, under Payment --> Make a Payment, is there a "Manage AutoPay" or "Register for AutoPay" option immediately to the right of the "One Time Payment" option?  It may or may not be there, and I've found that when the option is missing, it often means AutoPay isn't enabled for some reason.  If it says "Register for AutoPay", then it implies this isn't enabled.  In any case, I recommend you click on the "Manage my card" link (it's much smaller, below the "One Time Payment" option), then click on "Remove this credit card".  Then, click on the "Register for AutoPay" option under Payment --> Make a Payment.  Enter credit card and billing details, and click the Register button, and all should be good.
If you're missing AutoPay Reward credits (but you're seeing "Automatic Top-Up" in your Transaction History), then you'll have to contact the Moderators to make an adjustment for you...
Re: My stepdaughter
Thanks for the screenshots @Sarahmulder28!  That's helpful to get an idea of the billing to date.
It doesn't seem like the account is registered for AutoPay.  When you log into the account, under the overview, do you see "AutoPay Reward ($2)" under the "My Rewards" section?  And if you scroll down a bit further, do you see an "AutoPay" section, and does it say "You are currently registered for dynamic Autopay"?
In any case (whether you're registered or not), it doesn't hurt to de-register and then re-register for AutoPay, since there are glitches that seem to break the AutoPay functionality.  As mentioned previously, do so under Payment --> Make a Payment.  Depending on whether you see a "Manage AutoPay" or "Register for AutoPay" option, you can use those, or else go through the "Manage my card" link to remove and then re-add the credit card if the AutoPay option isn't showing up.
Re: My stepdaughter
I did that just now and yes it was on auto pay
Re: My stepdaughter
Then something's really fubar'd. None of those transactions show a line saying autopay reward.
And what's with all the top ups?
Re: My stepdaughter
The top up was from my bank
Re: My stepdaughter
Sure. But why? Did you tell it to? And again why? I guess this is Visa Debit and not a credit card then.
Re: My stepdaughter
I top up it up pot she travel to USA lot
Re: My stepdaughter
that my businessw i travel lot to usa
