10-05-2015 10:55 PM - edited 01-04-2022 12:46 PM
would this phone work?
LKD F5 Android 4.2 3G
Network type: GSM+WCDMA
Frequency: GSM 850/900/1800/1900MHz WCDMA 850/2100MHz
Support 3G : Yes
10-18-2015 12:07 AM
@Zepalz wrote:would this phone work?
LKD F5 Android 4.2 3GNetwork type: GSM+WCDMA
Support 3G : Yes
@Zepalz, based on those specifications, it should work. However, do note that LKD is not a known brand name, as such you may be stuck on Android 4.2 forever which poses a security issue. It's best to stick to known brands for this reason.
Here are some alternatives to consider:
Hope this helps!
10-06-2015 12:26 AM
Hi @Zepalz, your phone will work for Public Mobile 3G. However, there may be some places the reception is not good, due to only 850 but no 1900. I had Sony Xperia Z many years ago and only 850. But the price for your phone is good, also dual sim.
10-05-2015 11:07 PM
Hey @Zepalz,
Yes, this phone should work with 3G data on public mobile network.
Public Mobile uses 3G GSM bands: 850 and 1900 MHz.
