04-30-2019 04:45 PM - edited 01-05-2022 07:21 AM
I have looked through many many posts as I wait for a response from teh moderators, but no one has posted a solution that seems to work univeraslly. No pone has ever posted anything a moderator has told them to do to fix the issue. It seems like a very common bug (at least 400 posts that I could find). Why hasn't PM posted a legit solve for this bug? @CS_Agent
04-30-2019 05:24 PM
@rgruihn wrote:PM would rather see third party seller make proit on their bugs? This is bonkers. A bug this common MUST have a few unversal solves. OR maybe PM should actually supply real customer support.
I think @Alex888 provided a resonable short-term solution for you to get service going. It might be bonkers but if it works...hey ! Once it's up and running, then you can dig into why the cc won't "take".
In one of your many posts you noted that you need your phone for work. Perhaps Public Mobile isn't the best option for you, if your job requires cell service.
Once cell service has been established, I think you'll be glad you selected PM though.
Give that suggested short-term solution a try until the moderators can help you with resolution. Good luck.
04-30-2019 05:19 PM
I really can't disagree, it must be a major issue with the system else they would have fixed it.
04-30-2019 04:59 PM
04-30-2019 04:47 PM
