02-01-2021 01:07 PM - edited 01-05-2022 05:06 PM
I have just signed up for an account and my phone can not make calls except emergency
02-01-2021 02:48 PM
Having the emergency use only message means a few things.
You don't have a plan.
Verify on your PM Account.
Your SIM is not seated properly or not in your phone at all.
Reseat your SiM and reboot phone.
Also verify last 4 numbers on the SIM to your account information.
You phone needs the settings updated.
Reset your network settings.
Check as per @computergeek541 suggestions
And reboot your phone.
02-01-2021 01:18 PM
One thing to check would be to ensure that the network type isn't set to 2g as Public Mobile doesn't have that typen of network available.
02-01-2021 01:08 PM
@bsteinhoff wrote:I have just signed up for an account and my phone can not make calls except emergency
@bsteinhoff hi is your phone unlocked are you getting any message?
