05-24-2020 07:13 AM - edited 01-05-2022 10:53 AM
the valid referral code did not take any money off, what does it do?
05-24-2020 11:32 AM
If the checkmark was there it should happen.
If it was invalid code you wouldn't be able to advance to the next step
05-24-2020 09:53 AM
@shaaron wrote:the valid referral code did not take any money off, what does it do?
"Valid" is a tricky word. Maybe the code had an O and a 0 was typed instead. Or a 5 instead of an S. Or an L was written as lower case and a 1 was typed in. Or 2 instead of 7. Or 4 instead of 9. Or 6 instead of G.
Rewards don't "take any money off" until renewal. Credits appear in Available Funds and can be used towards the plan or to buy add-ons.
05-24-2020 09:46 AM
Hi @shaaron
Are you referring to your friends using yours or you using your friend's referral.
When you sign up and use it you will get $10 the next day usually. If it's longer than 72 hours and you are not getting anything then please contact moderators with your friend's code.
When your friend signs up they get that 10 within 72 hours, you should get an SMS that you made referral and you should see in your reward section the last 4 digits of their number. If you don't, please ask them to contact moderators with your referral code.
05-24-2020 09:03 AM
@shaaron if you have not received it after 3 to 5 days you will have to contact the moderators.
Click the question mark in the bottom right and type rewards missing, then contact us. And you can open a ticket.
Have a wonderful Sunday!
05-24-2020 08:11 AM
@shaaron everyone pays the full cost of the plan on sign up. Welcome to PM. Stay safe.
05-24-2020 07:43 AM
@shaaron If you just referred for the first time for the $20 bonus referral code it will be credited to your account within 30 days but sometime after June 5th. The $1 monthly reward should be showing in your account on the your overview page and your rewards page.
05-24-2020 07:19 AM
The referral can take up to 72 hours. The $1 referral award should be immediate as long as the person you referred has an active account.
05-24-2020 07:19 AM
@shaaron hi yes it works fine the person being referred will get 10 dollars in their account within 72 hours the person giving the code will get 1 dollar off every 30 day cycle
05-24-2020 07:15 AM - edited 05-24-2020 07:17 AM
@shaaron If you are the one that used the code, the money will show up in your account within I believe 2-3 days. (If its the current special referral of $20 for your first referral that will take up to June 5th). If you provided the code you will receive $1 off per month that the referred account is active.
