vouchers
scapper1
on a 10 dollar plan got a 20 dollar voucher cause 10 not available at kiosk  self serve says only good for 30 days why not 60
@scapper1
No need to worry then.
After November 9, you will be left with $14 for the next month.  The credit should not expire.
scapper1
balance shows 24 dollars and self serve says payment due on nov9
Dunkman
@scapper1
What does your balance show?  It should show the $20 or $10 after your payment date.  The amount does last until you use it up, so I don't think that you need to worry.
 If you want, you can screenshot your payment history (without personal information)  and display on this thread.
