voicemail
kz1
How do I turn off voicemail?
2 REPLIES 2
benfatto
Voicemail cancel completely; setup your voicemail not letting caller to leave a message.
https://www.publicmobile.ca/en/bc/get-help/articles/add-an-extended-absence-greeting
Follows the following flowchart to create extended absence greeting and don't let caller to leave message:
[3]Greetings --> [4]Extended Absence --> [2]Record
[3]Greetings --> [4]Extended Absence --> [5]Message not allowed after greeting
[3]Greetings --> [4]Extended Absence --> [4]Turn On
JoyLuck
https://www.publicmobile.ca/en/on/get-help/articles/add-an-extended-absence-greeting
To Disable Your Voicemail, Follow These Steps:
  1. Dial into your voicemail by holding the number 1 on your dial pad.
  2. Select option 3 to “Manage your greetings”
  3. Select option 4 to “Manage your Extended Absence Greeting”
  • Select Option 2 to record an extended absence greeting if you don’t already have one.
  1. If you have an extended absence greeting recorded, Select option 4 to turn on Extended Absence Greeting
  2. Select option 5 to block callers from leaving a message after hearing the Extended Absence Greeting
