02-14-2024 06:53 PM - last edited on 02-14-2024 07:09 PM by computergeek541
Hi,
I broke my iPhone which had an esim, I am using an old phone and I purchased a sim card at the store for it.
I can send and receive calls but can not send and receive text messages.
please help
thanks
02-14-2024 09:13 PM
Thank you, I have done that about 2 hours ago. Now some people texts are coming through and others not.
02-14-2024 07:09 PM
@Shelleynleg wrote:I am using an old huawei currently but my messages are going to my iphone instead of new phone i can hear it dinging. probably because whoever is texting me is using an iphone and its going through imessage
Please follow the instructions from the Apple website to disable your iMessage account. https://selfsolve.apple.com/deregister-imessage/
02-14-2024 07:00 PM
02-14-2024 06:55 PM - edited 02-14-2024 06:56 PM
hi @Shelleynleg are you using sms or iMessage??
check settings on iMessage and see if the phone number is correct Even if is, remove it and then reboot and put the number back
