11-17-2025
11:40 AM
11-17-2025
09:54 PM
computergeek541
I have a Canadian US Mexico phone plane . Can I us my phone when I am in the USA ?
11-18-2025 12:35 AM
Yes, you can use your phone in US or Mexico as long as it is compatible (VoLTE for calling). All you have to do is turn on Roaming from your phone settings once you get there.
11-17-2025 09:00 PM
Yes, if you have the Canada US mexico plan, you can use your phone in the USA and Mexico.
Which model phone do you have? For voice calling in the USA, you will need a VoLTE compatible phone with PM network.
Here is some additional information:
https://www.publicmobile.ca/en/get-help/articles/mex-subscription
https://www.publicmobile.ca/en/get-help/articles/volte
