08-30-2023
05:20 PM
08-30-2023
05:25 PM
computergeek541
I purchased a eSIM card, but it failed to activate it, and now my phone is out of service. what can I do now?
Joining Public
08-30-2023 05:29 PM - edited 08-30-2023 05:31 PM
@ka8000 ,
Try these below:
- Reset your Network Settings & reboot your phone
- In cellular settings make sure that “ Turn On This Line “ (for iPhone ) is selected. (I am not positive where the setting is on a different phone to turn it on, possibly ‘Turn on your eSIM under Mobile Network’)
- In your Cellular Network Settings manual select Public Mobile instead of Automatic
08-30-2023 05:22 PM
@ka8000 Have you rebooted the phone or reset network settings see if that helps. . If no luck please submit ticket with support to fix
send a private message To CS_Agents click
VVVVV Link below VVVVV
