transfer phone number
Jason-logic
Hi:
I am need to have public mobile resend the 'port' message to Koodo so my phone number can be transferred.  How does this happen?
Jason
@Jason-logic
The carrier you need to restart the porting process is the carrier you are porting into.
@Jason-logic Porting in?  there is a number to call, let me message you and you can talk to live support.  Check your Community inbox, envelope icon on top right
dust2dust
Which direction? Are you going out? Or coming in?
Jason-logic
I only have 60 minutes to get this done
