07-08-2024
11:05 AM
07-08-2024
04:43 PM
computergeek541
Rogers my prior provider had no restriction for transfer number but still strange phone number shownat my phone.
07-08-2024 12:54 PM
@keith10 normally the number transfer approval is sent via SMS to you. You can proceed with submitting the number transfer information in your online account while keeping the Rogers SIM card in the phone just in case a confirmation SMS is sent. Simply respond to the contribution SMS if received. Wait until connection is lost with the Rogers service which indicates that the number transfer is complete. Swap over to the Public Mobile SIM and the service should be running with the transferred number. Don't forget to update the eversafe credentials so that 2FA SMS will be sent to the correct number.
07-08-2024 11:19 AM
@keith10 It sounds like the port didn't complete and you've been assigned a new number. How long ago was the port from Rogers? You likely need to contact customer service, open a ticket at the chat icon bottom right of this page, or if that doesn't work send a private message to support using this link
07-08-2024 11:11 AM
don't understand, you got the text from Rogers and approved the port?
and then you tested the PM sim card? calls work both in and out or not at all?
07-08-2024 11:09 AM
just phone call with rogers, approval
07-08-2024 11:07 AM
you replied the Porting Authorization text from Rogers?
can you make calls on your PM sim? can you receive calls?
is it just a phone number problem with text?. or you can't even get any calls from others?
