texting
07-11-2023
05:41 AM
07-11-2023
08:36 AM
computergeek541
I keep getting message that my texts are not being sent public error 2 i have loads of data and this just started yesterday need the ability to receive and send texts as I am in contact with a person that only texts help!!!
Service
07-11-2023 11:33 AM
One of my phones had something like this a couple days ago. I chose to do a full power off restart. Maybe airplane would have worked. Maybe a simple restart too. But I went all the way. It fixed.
07-11-2023 06:23 AM
Try disabling any RCS services on the device by toggling off iMessage or Android chat, depending on which one may be being used.
If Android, try adjusting Chat messages options:
tap Messaging app,
tap 3 little dots top right,
select Settings,
under Chat settings, scroll to "Select default messaging type",
toggle it to Automatic or Text/multimedia msg
For Apple, adjust the iMessage settings:
tap the Settings app,
tap Messages,
turn iMessage off by toggling the switch to grey from green.
07-11-2023 06:13 AM
@ccgirl Hav e you tried rebooting your phone? Or reset network settings ? Also is it possible for you to try SIM card in another phone and see if services work correctly? . also check
Outage map in your area:
https://istheservicedowncanada.com/
if all else fails please
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
