06-12-2020 04:36 PM - edited 01-05-2022 12:11 PM
I was away from home with no wifi and I tried to send a text message 3 different times and the message stated not delivered what would cause that to happen?
06-23-2020 09:37 AM
06-22-2020 03:39 PM
@Naepalm wrote:@barbb are you on an iPhone using I message? With I message you have to have data on to send the message, it does not actually take up data but you need it on.
Is your data turned off while away from home?
@Naepalm FYI: if you force an iPhone to use only iMessage it will count towards your data usage when wifi is unavialable.
06-12-2020 05:19 PM
@barbb Make sure SMS and MMS are turned on within your iMessage settings.
06-12-2020 04:49 PM
Sounds like iPhone blues
If it's MMS then data must be on either Android or iPhone
06-12-2020 04:39 PM - edited 06-12-2020 04:42 PM
06-12-2020 04:39 PM
@barbb what's the make and model of your phone? Thanks. Stay safe.
06-12-2020 04:38 PM
