subscription
Bilo14
I changed my plan by mistake, I want to go back to the $34 plan but it is not in my profile anymore
Bilo14
Problem solved! Thanks  Phil_Adelphus.
Bilo14
ok, thanks
Phil_Adelphus
@Bilo14  The $34 subscription is now for new activations only so I rather doubt you can get it back, but you can try asking customer support by private message using this link
An agent will reply at your community inbox, either envelope icon top right or tap your avatar for Messages
