02-28-2024 07:48 PM
02-28-2024 07:49 PM - edited 02-28-2024 07:50 PM
That's tough @dmmotyka1
You can try your luck with a customer support agent if it was very recently
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
