03-08-2024
09:39 PM
03-09-2024
12:47 AM
computergeek541
Just signed up for a new plan. Choose the esim and number port from Koodo. Now my account just says subscription not activated and to contact customer service. The credit card charge was posted successfully. Need help please
03-08-2024 09:52 PM
Yes I did choose the esim option, although I'm using a physical SIM with Koodo but would like to switch to esim on my pixel 5. I don't see any public mobile esim in my esim settings. I sent a direct message since the ticketing portal isn't loading for me .
03-08-2024 09:41 PM
hi @shubz
did you try to activate esim? if you do, check the sim manager, is the PM esim there?
or you can ask support agent to check the account activation
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
