subscription not activated
jasintha2019
hi i have transfering my number from telus prepaid but i have message in public mobile its  SUBSCRIPTION NOT ACTIVATED ,  i want some one help me out this issue
jasintha2019
hi thanks can i have the porting number pls
@jasintha2019 I’ll send you the porting number private message . Call them they can give status update on the port or re trigger it if needed . If your still having issues I’ll leave you with this first link to support for further assistance
send  a  private message   To CS_Agents
Cheetah24
@jasintha2019: hey, for porting related issues you should contact the service agent at, https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437. They'll be able to help you out.
