08-08-2026 02:00 PM
08-08-2026 02:02 PM
hi @Dimamon if you can login My Account, check if the extra money you paid is showing as Available funds, you can leave them there if you like it will be used for future payment
but if you need PM agent to help, submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
