sim card
waylonrose
hi! just activated sim card but it won't work?
JoyLuck
Was your cc charged. If yes then put sim in phone and see if it works. If no try activating again in 1 hour. The sim might be locked after too many attempts.
geopublic
@waylonrose  If you dial 611 what happens?
kb_mv
@waylonrose Did you try restarting your phone after activating? Are you showing registered on Public Mobile network? Is nothing working?
dabr
@waylonrose   Double check you entered the correct SIM numbers and then reboot your phone.
