sim activation
john881
When I receive a call it goes directly to voimail
8 REPLIES 8
@john881 Great to hear that the porting is going work out soon.
Welcome to PM once everything is completed and enjoy the savings.
@john881 wrote:
I have it need to give it to public mobile to complete my number tranfer
Contact Moderators like this, make sure to tell them you're supplying an IMEI number to complete a number transfer.
To contact a moderator, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type moderator assistance, then select account-related issue, then select you need a human now.  Follow the prompts to submit a ticket,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
john881
@john881 wrote:
I found out I put wrong imei# from my provider primus mobile
To get correct IMEI number, dial this from device:
*#06#
john881
HALIMACS
Try these steps:
  1. take off airplane mode
  2. take off do not disturb
  3. ensure the number calling you is not on blocked senders list
  4. disable any call-forwarding features
  5. turn off Bluetooth device if it's possible the 'ringing' is going through to it instead of device's speakers
  6. remove and replace your SIM card
  7. reset network connections
  8. reboot device
benfatto
@john881  Did you request a transfer of number from another carrier? If so, does your old SIM still work.
Did you ask for a number to be ported in?  If you did, that voicemail could be that of the service from your old carrier.
