self serve account
yeni554
Hello
I connot create self serve Account it say phone number invalid,i have this number last 3 years
try it different browser internet
will13am
@yeni554, if you are unfamiliar with moderator team interaction, the moderator team can be reached via private message using this link.  Please include in the private message account number and PIN code along with a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
mimmo
@yeni554 are you a legasy customer?  How have you dealt with paid for your account before without a selfserve account?
If you don't have an account and are getting an error then only mods can help you.  You will need to send them a private mrssage
