roaming in the US
hamidgs
Hi,
I am going to travel to the US in the next week. I am wondering if my phone works there!
thanks
Brooke_C
Retraité / Retired
Retraité / Retired
Hey @hamidgs@the1nonly214, and @DK,
Great news- We are launching US roaming in November! Check out the full details here
the1nonly214
If thankful and you are satisfied with the resolution please offer @DK a bravo and mark his response as solved.
hamidgs
Great, I will buy one.
the1nonly214
just in addition to what @DK said, you can get Roam Mobility sim cards in store at best buy and staples.
hamidgs
thanks
DK
No to roaming with PM. They don't offer it so won't work.
If phone is unlocked you can use www.roammobility.com and there rates are very good. The sim is $10 and setup is all done online.
Cheers
