12-09-2019 10:09 PM - edited 01-05-2022 08:27 AM
good evening,
I am trying to sign on to my self service but I have forgot my password. I tried to ask for a link to change my password but it doesnt work. It states my account is locked.
Honestly it has probably been about 6 months or so since I have signed onto my self service so I dont know if that has something to do with it.
I need to get this fixed so I can move on.
Thanks
12-28-2019 09:40 PM
@maybucknell wrote:I’m forget my password I need help to restating my password my account
First try https://selfserve.publicmobile.ca/forgot-password/ for the regular password reset option.
If that doesn't work, you'll need to open ticket by going to https://publicmobile.ca.ada.support/chat/
12-28-2019 01:58 PM
12-10-2019 01:21 AM
It says your account is locked because you might have entered the incorrect password more than the said limit. And there is problem with their forget password system which sends you a password reset email after a few hours. So you gotta have an eye out for it when it reaches the inbox because the link usually expires in an hour or two. Good Luck!!
12-09-2019 11:22 PM
I have been able to reset my password.
Thanks for all the help. At the end I just needed to wait for my account to be unlocked. I was able to ask for a new password and the reset link worked on the first try.
I think i need to remember to sign in occasionally and from a computer and not just the phone.
Thanks all
12-09-2019 10:57 PM
@aero12 wrote:Thanks
You are welcome, hope everything gets sorted quickly!
12-09-2019 10:56 PM
Thanks
12-09-2019 10:52 PM
I also have a ticket. does the moderator call the cell number or the alternative number.
Conversation with the moderators will be by private message. Turn your e-mail notifications on to not miss it.
12-09-2019 10:51 PM
They will not call the numbers, they contact you via the account you use to submit the ticket.
12-09-2019 10:46 PM
Thanks
12-09-2019 10:43 PM
@aero12 wrote:Yes my account is active. I recently recevied the email regarding free gift. I tried to sign on to my account but go locked because it has been more than 6 months since I have signed on to my self serve account.
Locked out usually just needs a wait. Like an hour. It wouldn't be because you haven't logged in for a while.
12-09-2019 10:39 PM
12-09-2019 10:28 PM
@Ed404 wrote:Do you currently have an active plan?
Same direction... if your plan is not active: after 90days of suspension you loose / have lost your account and number.
12-09-2019 10:18 PM
@aero12 wrote:good evening,
Thanks
Everything seems to be a mess right now from the community to the self-serve. You can submit a trouble ticket but there seem to be issues with customers being able to respond to the messages the moderators are sending.
Click this link https://publicmobile.ca.ada.support/chat/ and enter your question into SIMon. Follow the prompts to get to the Contact Us button and then a Submit Ticket button will appear.
Community Moderators are available from Monday-Friday 8 am(Eastern) to 12 am(Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm(Eastern)
12-09-2019 10:13 PM
