referral code
Stirling182
Hi
My referral code was always visible but now I can't seem to find it anywhere.  Have they moved it?
thanks
Stirling182
I was using the DT version, which I will assume was why it wasn't showing up properly..the app is much easier
slusagm
you can find your referral code on the Rewards site as well
Chalupa_Batman
@Stirling182 wrote:
Hi
thanks
Hello @Stirling182
You can find it in many places. First, when you log in, at the top of the page is Sharing is Caring and your code is there. When you click on My Referrals tab on the left side panel, once again, the first banner up top is Sharing is Caring and your code is there. If you don't see it there in these two places, then you may wish to clear your cache and restart your browser.
SKSuh
Using the app, check the “account” tab for your referral code
