"Uleway" phones, Compatibility on Pub'Mob' ?
dougc
"Uleway" (amazon supplier)  claims that their (Red on silver) units are compatible with Telus;
"Uleway 3G  flip phone ,works with  . . . Telus (Koodo),  . . .  or any carrier operates on these networks.
Band Mode:GSM 850/900/1800/1900mHz ,WCDMA 900/2100 mHz or 850/1900 mHz.  "
But "Uleway" is not found listed in the   (Public Mobile) Getting Started > Compatiblity utility !
Anyone acquired this flip phone  unit,  or possibly another in the Uleway line-up,   and 'found' successful use with Pub'Mob' network ?
Staliger
@dougc if it works with Telus, it will work with PM. Many phones that are not in the PM's supported list, operate perfectly with PM.
geopublic
@dougc  Yes, it will work.
This means that this model/brand has 2 different version. Make sure that you get the one with WCDMA 850/1900MHz or it won't work.
