10-29-2022 07:36 PM
Is public mobile compatible with the iphone SE 2022. I currently have iphone 6S and would like to purchase the iphone SE 2022 and keep my current account.
Thank you.
10-29-2022 10:07 PM
10-29-2022 08:01 PM
Thank you!
10-29-2022 07:56 PM - edited 10-29-2022 07:57 PM
HI @Sandra7000
three are different ways to move. iCloud or iTune are the easiest I think
https://www.wideanglesoftware.com/blog/how-to-transfer-photos-from-iphone-to-iphone.php
10-29-2022 07:54 PM
Ok but I have to move the data from iphone 6 to inphone SE to keep the data. photos, contacts etc. right.
10-29-2022 07:44 PM - edited 10-29-2022 07:46 PM
Yes. But get one that's made for North America.
10-29-2022 07:43 PM
Are all the new iphones compatible with public mobile?
10-29-2022 07:43 PM
Yes the iPhone SE is compatible with PM.
All you need to do is remove the SIM from the iPhone 6S then put it in the iPhone SE so it will be seem-less switch.
10-29-2022 07:40 PM
@Sandra7000 wrote:Is public mobile compatible with the iphone SE 2022. I currently have iphone 6S and would like to purchase the iphone SE 2022 and keep my current account.
Thank you.
Yes, it's most definitely compatible.
10-29-2022 07:40 PM
Yes that'll work. No problem.
