puk code
atul007
i have lenovo s660
it is unlocked never associated with any carrier company
asking me for puk code
7 REPLIES 7
@atul007 wrote:
when can moderators send me puk code
Messages are generally managed first come first served. So, you may not have a response until tomorrow.
If you have a spare SIM you can login to your account and go to Change SIM.
atul007
@atul007 wrote:
it is supported yesterday and today it is asking for puk how it was possible
i insert PM sim in iphone unlocked phone still it is asking me puk code
OK. Then the SIM has been (accidently?) locked and you will need to wait for the moderators to send you the PUK. They will need your SIM card #.
Suggest you unlock the SIM in the iPhone.
Good luck.
atul007
@atul007 Don't bother. Your phone is not compatible with PM's network. This is from https://willmyphonework.net
Device Frequencies Lenovo S660  Carrier Frequencies Canada Public Mobile
2G Network:
3G Network:
4G LTE Network:
Carrier Network does not support 2G
Device not compatible
Device does not support 4G LTE bands
JDT means you should send them a private message; I think.
JDT
If you contact the @CS_Agent, they should be able to provide you with the PUK code.
