problems with voicemail
Lorna1
People are unable to leave me a voice message. They get a recorded message that tells them to put in some code and then asks what language they want to use????????
Timer
@Lorna1
How To Use Voicemail Features (publicmobile.ca)
check your device Voicemail Access Numbers - (publicmobile.ca)
and rebooting device.
dust2dust
Is this an iphone or Android? Some of the voicemail access numbers are being changed.
Outdoorsman
@Lorna1 hi it sounds like you need to setup your voicemail
  https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
