porting
07-09-2019 11:54 AM - edited 01-05-2022 05:48 AM
07-09-2019 12:11 PM
I agree with all the above. You can actually port during activation, but the reason it is suggested to port after activation, is that ocassinailly there are activation issues. And if those occur it is better they happen to a temp number rather than a ported number.
07-09-2019 12:01 PM
What they all said!
07-09-2019 11:59 AM
@gregpieper wrote:when do you port a number ..after you buy a sim card?
@gregpieper Best to activate the PM sim with a temporary number and once the sim is activated and your selfserve account is created then you can do the port online through your selfserve account.
07-09-2019 11:58 AM
Also don't cancell plan with old carrier before port to PM is complete. PM will cancell old plan automatically.
07-09-2019 11:55 AM
Port after you buy and activate your SIM
