porting text resend
protonstation
how can i get puplic moble to resend porting text
2 REPLIES 2
@protonstation
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
@protonstation
Submit a ticket with Public Mobile representatives (CSA) for help; click this link for issues with transfer/porting of phone numbers over to Public Mobile.
Or, you can try calling the Telus porting phone number, which we are not supposed to post here. So, check your private messages I will send it to you there.
